hussains1980
Mar 04, 2022Tutor
I have wifi but dont?
Our power went out last night for three hours and since the wifi came back on and I am on my laptop but my TVs and phone no longer work even though I have reconnected them. I also can not access spec...
Mar 04, 2022Guru - Experienced User
1. what actual firmware version are you on?
2. does it impact wired devices as well as wireless?
3. have you tried a simple factory reset and reinstall? Maybe something is corrupt in the settings from the power outage.
4. If the reset doesn't help, do you have a screen snip of the cable connections page and the event logs?
