drsolaris
Aug 27, 2019Aspirant
I keep on loosing internet connection after switching from optimum provided (leased) cable modem
I keep on loosing internet connection after switching from optimum provided (leased) cable modem with BYOD CM1000 from netgear please see attached file for details.
drsolaris
Sep 13, 2019Aspirant
I got new modem which I think worked fine for couple of days but now those errors are back and at present it is very bad dropping connection constantly. See attached pdf files which has events log.
Sep 13, 2019Guru - Experienced User
Did you get the same model modem or something different.
Anything near your modem like other electronic devices by chance. Where is the modem placed?
If a new modem is now doing the same thing, seems like ISP needs to look at there logs and the condition of the modem signal when this is happending so they can see whats going on. You may need to get a modem from the ISP for short term use and see if it happens there. IF it does, then the ISP needs to figure this out.
- drsolarisSep 13, 2019Aspirant
I did get a modem from ISP which I tried for couple of days. Here are event logs from ISP leased modem.
