Hawkwing2000
Mar 03, 2020Aspirant
I own a C6300 v2 AC1750 Router Modem combo and it randomly reboots
Hi, My router has been rebooting almost every night, usually at the worst possible time. I'm not sure why so I printed the event log hoping someone could give me some direction. I was using a Moto...
vkdelta
Mar 04, 2020NETGEAR Employee Retired
pls provide power value screenshot as well.
- Hawkwing2000Mar 04, 2020Aspirant
Is this what you need? Not sure where else it would be:
Downstream Bonded Channels
Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables UnCorrectables 1 Locked QAM 256 1 459000000 Hz -1.7 dBmV 38.9 dB 0 0 2 Locked QAM 256 2 465000000 Hz -1.7 dBmV 38.9 dB 24 0 3 Locked QAM 256 3 471000000 Hz -1.7 dBmV 38.9 dB 26 0 4 Locked QAM 256 4 477000000 Hz -1.9 dBmV 40.3 dB 0 0 5 Locked QAM 256 5 483000000 Hz -1.7 dBmV 38.6 dB 0 0 6 Locked QAM 256 6 489000000 Hz -2.0 dBmV 38.9 dB 17 0 7 Locked QAM 256 7 495000000 Hz -2.0 dBmV 38.6 dB 0 0 8 Locked QAM 256 8 507000000 Hz -1.7 dBmV 38.9 dB 6 0 9 Locked QAM 256 9 513000000 Hz -1.7 dBmV 38.9 dB 24 0 10 Locked QAM 256 10 519000000 Hz -1.9 dBmV 38.9 dB 11 0 11 Locked QAM 256 11 525000000 Hz -2.0 dBmV 38.9 dB 27 0 12 Locked QAM 256 12 531000000 Hz -2.2 dBmV 38.9 dB 12 0 13 Locked QAM 256 13 543000000 Hz -2.4 dBmV 38.9 dB 9 0 14 Locked QAM 256 14 549000000 Hz -2.5 dBmV 38.9 dB 20 0 15 Locked QAM 256 15 555000000 Hz -2.4 dBmV 38.6 dB 16 0 16 Locked QAM 256 16 561000000 Hz -2.2 dBmV 38.9 dB 37 0 Upstream Bonded Channels
Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 3 5120 Ksym/sec 17300000 Hz 49.5 dBmV 2 Locked ATDMA 4 5120 Ksym/sec 23700000 Hz 51.0 dBmV 3 Locked ATDMA 1 5120 Ksym/sec 30100000 Hz 51.0 dBmV 4 Locked ATDMA 2 5120 Ksym/sec 36500000 Hz 51.0 dBmV Current System Time: Wed Mar 4 18:47:52 2020System Up Time: 02:35:08
vkdelta wrote:pls provide power value screenshot as well.
- vkdeltaMar 05, 2020NETGEAR Employee Retired
yes, too high Upstream power.
do you have splitters? If yes, Please remove it.
What do you mean by reboot? Is the whole box rebooting? or just loosing internet.
- Hawkwing2000Mar 06, 2020Aspirant
I don't have any splitters, and I'm getting a new coax cable. What else could be causing the higher power output?
