MS70
Jan 17, 2024Star
I think the the CM1200 has fallen off their list
With Comcast anything is possible… I think the the CM1200 has fallen off their list. I’ve been struggling to get connection back to where it was. While they say everything looks fine on their end and...
Jan 17, 2024Guru - Experienced User
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Are you streaming via wireless or wired ethernet to your streaming device?
Can you connect your streaming device directly to the Modem with out the RAXE in the mix to see if streaming is not pixelated? Help rule out the modem or router here.
Do you have IPv6 setup and Auto on the RAXE router?
How do you have the RAXE router connected to the CM series modem? Using the Yellow WAN port in back of the RAXE router?
As of Nov of last year the CM1200 was still on there supported modems list:
Kitsap
Jan 17, 2024Master
Here is a more recent list:
On the recommended list for connection to the Comcast standard network. The CM1200 does not yet have the certified firmware to connect to the Comcast enhanced speed network with the 100/200 Mbps uploads.
