MS70
Jan 17, 2024Star
I think the the CM1200 has fallen off their list
With Comcast anything is possible… I think the the CM1200 has fallen off their list. I’ve been struggling to get connection back to where it was. While they say everything looks fine on their end and...
Jan 29, 2024Guru - Experienced User
How do you have the wifi router configured for IPv4 and IPv6 for the xbox?
Is the xbox wireless or ethernet connected to the router?
MS70
Jan 29, 2024Star
Xbox is ethernet wired... I set the IPV6 back to DHCP (how it was always set on the old router, DNS to auto get from ISP, Use DHCP server on the LAN setup. NAT filtering open.
That sorted it out... Problem is come back later in the day or next day and it can't log in again... Got a new message that said “Can't get a Teredo IP Address”. Did a hard reset and it logged in fine. Just tested again this evening and it logged in fine... so hopefully it's good now. Shouldn't need to be doing hard resets or clearing Mac address constantly for it to log in.
- FURRYe38Jan 30, 2024Guru - Experienced User
Is the RAXE300 router the only router you have on hand by chance?
Please post a new copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router - MS70Feb 01, 2024Star
So Xbox started up fine for two nights then try to get it going after logging off work VPN and it's the same thing again... Shows IPV4 & 6 but can't resolve the NAT/Teredo stuff.
Only other router I have is the older NightHawk R7800.
Had to reboot the modem and hook up laptop directly to get access to modem admin page. The diagnostic was all green. Modem log in next post.
Modem log. Similar errors as the other one. To be honest every modem I've ever owned, Netgeat and going back to the Motorolla Surfboards has ALWAYS had errors galore with Comcast. At least this one is showing up on the Xfinity app as connected.
Why can't Netgear and Xfinity get their act together??? They sell these products as “compatible with Xfinity”. I'm not buying it anymore. $600 in and it's still nothing but problems. Stockholder too and I'm fed up with this company... Stock has been garbage for 5 years. Used to be a good brand, now not so much.
- MS70Feb 03, 2024Star
This stupid router probably needs another firmware update because it's not doing what it should with regard to UPnP/Teredo and NAT. It gets Moderate NAT. Clear MAC Addy and restart... the same again. Check NAT and Xbox suggests making sure UDP Port 3544 isn't blocked. Open port forwarding on UDP 3544, still no improvement. RAXE300 Piece of junk!
[UPnP set event: add_nat_rule] from source: 192.168.1.200, Saturday, February 03, 2024 21:43:41
[UPnP set event: GetExternalIPAddress] from source: 192.168.1.200, Saturday, February 03, 2024 21:43:41
[DHCP IP: (192.168.1.200)] to MAC address d8:e2:df:4c:c3:0d, Saturday, February 03, 2024 21:43:30
[DHCP IP: (192.168.1.200)] to MAC address d8:e2:df:4c:c3:0d, Saturday, February 03, 2024 21:42:11
[UPnP set event: GetExternalIPAddress] from source: 192.168.1.200, Saturday, February 03, 2024 21:41:10
[UPnP set event: GetExternalIPAddress] from source: 192.168.1.200, Saturday, February 03, 2024 21:41:06
[LAN access from remote] from 40.81.122.229:3544 to 192.168.1.200:3074, Saturday, February 03, 2024 21:40:49
[UPnP set event: add_nat_rule] from source: 192.168.1.200, Saturday, February 03, 2024 21:40:43
[UPnP set event: GetExternalIPAddress] from source: 192.168.1.200, Saturday, February 03, 2024 21:40:27
[UPnP set event: add_nat_rule] from source: 192.168.1.200, Saturday, February 03, 2024 21:39:05
[UPnP set event: GetExternalIPAddress] from source: 192.168.1.200, Saturday, February 03, 2024 21:39:05
[DHCP IP: (192.168.1.11)] to MAC address 8c:85:90:1d:5f:fb, Saturday, February 03, 2024 21:37:20
[UPnP set event: DeletePortMapping] from source: 192.168.1.200, Saturday, February 03, 2024 21:36:03
[UPnP set event: GetExternalIPAddress] from source: 192.168.1.200, Saturday, February 03, 2024 21:36:03
[UPnP set event: add_nat_rule] from source: 192.168.1.200, Saturday, February 03, 2024 21:34:57
[UPnP set event: GetExternalIPAddress] from source: 192.168.1.200, Saturday, February 03, 2024 21:34:57
[UPnP set event: DeletePortMapping] from source: 192.168.1.200, Saturday, February 03, 2024 21:34:48
[UPnP set event: GetExternalIPAddress] from source: 192.168.1.200, Saturday, February 03, 2024 21:34:48
[LAN access from remote] from 40.81.122.229:3544 to 192.168.1.200:3074, Saturday, February 03, 2024 21:33:43
[UPnP set event: add_nat_rule] from source: 192.168.1.200, Saturday, February 03, 2024 21:33:39
[UPnP set event: GetExternalIPAddress] from source: 192.168.1.200, Saturday, February 03, 2024 21:33:39
[DHCP IP: (192.168.1.200)] to MAC address d8:e2:df:4c:c3:0d, Saturday, February 03, 2024 21:33:36
