MS70
Jan 17, 2024Star
I think the the CM1200 has fallen off their list
With Comcast anything is possible… I think the the CM1200 has fallen off their list. I’ve been struggling to get connection back to where it was. While they say everything looks fine on their end and...
MS70
Feb 02, 2024Star
Modem log. Similar errors as the other one. To be honest every modem I've ever owned, Netgeat and going back to the Motorolla Surfboards has ALWAYS had errors galore with Comcast. At least this one is showing up on the Xfinity app as connected.
Why can't Netgear and Xfinity get their act together??? They sell these products as “compatible with Xfinity”. I'm not buying it anymore. $600 in and it's still nothing but problems. Stockholder too and I'm fed up with this company... Stock has been garbage for 5 years. Used to be a good brand, now not so much.
MS70
Feb 04, 2024Star
This stupid router probably needs another firmware update because it's not doing what it should with regard to UPnP/Teredo and NAT. It gets Moderate NAT. Clear MAC Addy and restart... the same again. Check NAT and Xbox suggests making sure UDP Port 3544 isn't blocked. Open port forwarding on UDP 3544, still no improvement. RAXE300 Piece of junk!
[UPnP set event: add_nat_rule] from source: 192.168.1.200, Saturday, February 03, 2024 21:43:41
[UPnP set event: GetExternalIPAddress] from source: 192.168.1.200, Saturday, February 03, 2024 21:43:41
[DHCP IP: (192.168.1.200)] to MAC address d8:e2:df:4c:c3:0d, Saturday, February 03, 2024 21:43:30
[DHCP IP: (192.168.1.200)] to MAC address d8:e2:df:4c:c3:0d, Saturday, February 03, 2024 21:42:11
[UPnP set event: GetExternalIPAddress] from source: 192.168.1.200, Saturday, February 03, 2024 21:41:10
[UPnP set event: GetExternalIPAddress] from source: 192.168.1.200, Saturday, February 03, 2024 21:41:06
[LAN access from remote] from 40.81.122.229:3544 to 192.168.1.200:3074, Saturday, February 03, 2024 21:40:49
[UPnP set event: add_nat_rule] from source: 192.168.1.200, Saturday, February 03, 2024 21:40:43
[UPnP set event: GetExternalIPAddress] from source: 192.168.1.200, Saturday, February 03, 2024 21:40:27
[UPnP set event: add_nat_rule] from source: 192.168.1.200, Saturday, February 03, 2024 21:39:05
[UPnP set event: GetExternalIPAddress] from source: 192.168.1.200, Saturday, February 03, 2024 21:39:05
[DHCP IP: (192.168.1.11)] to MAC address 8c:85:90:1d:5f:fb, Saturday, February 03, 2024 21:37:20
[UPnP set event: DeletePortMapping] from source: 192.168.1.200, Saturday, February 03, 2024 21:36:03
[UPnP set event: GetExternalIPAddress] from source: 192.168.1.200, Saturday, February 03, 2024 21:36:03
[UPnP set event: add_nat_rule] from source: 192.168.1.200, Saturday, February 03, 2024 21:34:57
[UPnP set event: GetExternalIPAddress] from source: 192.168.1.200, Saturday, February 03, 2024 21:34:57
[UPnP set event: DeletePortMapping] from source: 192.168.1.200, Saturday, February 03, 2024 21:34:48
[UPnP set event: GetExternalIPAddress] from source: 192.168.1.200, Saturday, February 03, 2024 21:34:48
[LAN access from remote] from 40.81.122.229:3544 to 192.168.1.200:3074, Saturday, February 03, 2024 21:33:43
[UPnP set event: add_nat_rule] from source: 192.168.1.200, Saturday, February 03, 2024 21:33:39
[UPnP set event: GetExternalIPAddress] from source: 192.168.1.200, Saturday, February 03, 2024 21:33:39
[DHCP IP: (192.168.1.200)] to MAC address d8:e2:df:4c:c3:0d, Saturday, February 03, 2024 21:33:36
