oskcorn
Feb 25, 2023Aspirant
I tried NG fixes, no good. Deleted all CAX30 info from PC, reset, reinstalled, as if new
I tried NG fixes, no good. Deleted all CAX30 info from PC, reset, reinstalled, as if new. It worked for about 18 hours and back to square one. What I don't understand, if they can update firmware aut...
- Feb 27, 2023
FINALLY! SUCCESS! The last steps were to use Chrome instead of Edge, and because the modem connection came up unsecured, I needed to bypass the warning to get the chance to upload the old version to the router. After that, I had to reset the network at the destinations. CAUTION: Those still using the modem to hardwire to their PC, based on my experience of getting unsecured connections, it seems the firmware problem may have also affected the security of the modem in addition to the Wi-Fi. Thank you for your patience and knowledge. BTW, I used to write software using BAL on the IBM 370 series under POWER. De-bugging software was so much easier. Plenty of logic, but not much useful knowledge today. LOL
oskcorn
Thanks for the first step. I downloaded the file and when I unzipped it, I got a .bin file. I'm using Windows 11 and don't know what's next. Can you help?
Feb 27, 2023Guru - Experienced User
If you still have access to the modems web page, send the .bin file to the modems web page under Admin/Router Update using a wired PC and web browser.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
- oskcornFeb 27, 2023Aspirant
As my luck would have it, I logged into my modem page that opened up in the basic tab. When I click on advanced, it asks me to login again. When I do, it says I am logged in from another device and wants to know if it/they would log me out of this other device (I am not logged in elsewhere). I selected to logout of this other location, and I'm again asked to login. It is an endless loop. PLAN C?
- FURRYe38Feb 27, 2023Guru - Experienced User
What does selecting OK do?
Try powering Off the modem for 1 minute then back ON then log in with a wired PC.
Clear all browser caches before entering the web page...
Try a different browser.
