oskcorn
Feb 25, 2023Aspirant
I tried NG fixes, no good. Deleted all CAX30 info from PC, reset, reinstalled, as if new
I tried NG fixes, no good. Deleted all CAX30 info from PC, reset, reinstalled, as if new. It worked for about 18 hours and back to square one. What I don't understand, if they can update firmware aut...
- Feb 27, 2023
FINALLY! SUCCESS! The last steps were to use Chrome instead of Edge, and because the modem connection came up unsecured, I needed to bypass the warning to get the chance to upload the old version to the router. After that, I had to reset the network at the destinations. CAUTION: Those still using the modem to hardwire to their PC, based on my experience of getting unsecured connections, it seems the firmware problem may have also affected the security of the modem in addition to the Wi-Fi. Thank you for your patience and knowledge. BTW, I used to write software using BAL on the IBM 370 series under POWER. De-bugging software was so much easier. Plenty of logic, but not much useful knowledge today. LOL
Feb 27, 2023Guru - Experienced User
What does selecting OK do?
Try powering Off the modem for 1 minute then back ON then log in with a wired PC.
Clear all browser caches before entering the web page...
Try a different browser.
oskcorn
Feb 27, 2023Aspirant
- FURRYe38Feb 28, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
