gregorywelch
Mar 15, 2020Guide
If I purchase a new C3700 should it be a C3700v2?
The Netgear web site only lists the C3700 for sale. My ISP and need for NAT loopback require a C3700v2. Is it (likely) the case that when I purchase a C3700 from Netgear (say) it will actually be a C...
Mar 15, 2020Guru - Experienced User
Other than having the box in hand, if you order online, most won't know what they're sending you. I've ordered specific versions of devices before and go the wrong one. again, if you NEED that specific version, go to a strore so you can check the model number showing v2.
