Wryker
Dec 13, 2023Aspirant
I'm maxed at 880 with my CM1000
I got the message for Xfinity too since even though when I bought my modem it said it'd support the high speeds - it doesn't.
So even though I have 1gb plan, I'm maxed at 880 with my CM1000.
So w...
Wryker
Dec 14, 2023Aspirant
Dang it. So I guess I'll just suffer w/the lower speeds.
I'd hate to buy a newer model only to have an issue with their higher speeds in the next few years.
Unless that will never happen?
Dec 14, 2023Guru - Experienced User
Ask your self, can you get by with 800Mpbs. If so, You'll be good for a while longer with the CM1000.
