mjalaal
Aug 13, 2019Aspirant
im tired of this [DoS attack: Ping Of Death]
I get hundreds of these logs in my router, when this happens, the speed drops from 30mb to 400kb or less, please help im not enjoing the internet anymore I traced the problem it it's coming from the...
Aug 15, 2019Guru - Experienced User
Contact your ISP and have them help you block thsi IP. Have them also change your WAN IP address.
mjalaal wrote:I get hundreds of these logs in my router, when this happens, the speed drops from 30mb to 400kb or less, please help im not enjoing the internet anymore
I traced the problem it it's coming from the ipad , I did the following
Uninstall all apps
reboot
reset factory
all didnt work, once i connect, i get the same attack and internet drops, I was readying on the forum, they all said they replaced the netgear to silve the problem, do i really need to do so?
[DoS attack: Teardrop or derivative] from 128.2.88.0, port 0
[DoS attack: Ping Of Death] from 128.2.88.0, port 0
- mjalaalAug 19, 2019Aspirant
I have this problem since 3 months now, I did contact them over 10 times, I have no idea what to do , but when i browsed the forum I found that several compains about the same exact essue between apple device and the netgear ... read this
I almost did everything I can:
factory reset the iPad
factory reset the netgear
changed passwords
format iPad
change WAN password and connect only iPad ( DoS attak appear in a few seconds, kills internet )
changed WAN Password and connect all devices except iPad ( internet works fine )
should I gave up and just buy motorolla ?
- FURRYe38Aug 20, 2019Guru - Experienced User
Probably. I would get in to a stand alone modem something like a MB7420, then connect up a external wifi router.
Good Luck.
