JCHelp
Jun 13, 2023Follower
In simple terms, how to change ip address?
ELI5, how would I go about changing my ip address on the c7000v2. I read somewhere it might not be possible on 2 in 1 systems. Is it through static ip changes? Thanks.
peterwoods573
Jun 13, 2023Aspirant
Tap Wi-Fi under Connections in the Android Settings menu.
the gear-shaped icon) next to the network you're now connected to.
Select Static under IP settings. Tap Save after adding your new IP address.
