ran-d
Oct 03, 2022Aspirant
Incorrect service provider - AX6 CAX30
I recently purchased the AX6 CAX30 modem router when I switched internet providers from CenturyLink to Orbital. When I run speed tests (speedtest, speakeasy, ATT, Spectrum...), they're all showing my...
Oct 04, 2022Guru - Experienced User
It could be orbital purchasing capacity or area from centurylink. Centurylink might still be running the backhaul or even fronthaul of it with just orbital being the reseller to you.
If everything is working and you're getting the required speeds, I wouldn't worry to much about it.
- ran-dOct 04, 2022Aspirant
Thanks all.
- FURRYe38Oct 04, 2022Guru - Experienced User
Enjoy. 📡
