paulmgrinnell's avatar
Feb 16, 2024
Increase Performance
Can anyone suggest how to increase performance of my C7000v2 (AC1900) with Xfinity? Thank you.  (This is my first self managed router/modem)
  • Kitsap's avatar
    Feb 18, 2024
    The technical design of your C7000v2 is very old.  If you can, recommend you return it to the vendor and exchange it for a newer design.  Recommend a DOCSIS 3.1 type device.
    Next time, you need to define what you mean by performance.  Data throughput?  Wi-Fi range?
