KaseyW
Jun 02, 2022Aspirant
Insecure Password Reset?
When I tried to wake up my LG Windows 10 laptop this morning, although my WiFi was active, my Netgear AC1900 WiFi Cable Modem Router was not connected to the internet. So I tried what usually works ...
- Jun 03, 2022
Shouldn't be any cause for concern. I've seen the default configuration change from being able to use default login info to requiring a change. Could be it just took your isp this long to push it out
Jun 02, 2022Guru - Experienced User
why not just log in through the browser and set it up?
Its pretty common for the default password to be required to be changed. If there was firmware pushed out from the ISP for that, more than likely thats causing it.
You could always just factory reset and run through the install wizard.
KaseyW
I may be confused, but I'm not sure what you mean by "just log in through the browser." What opened was a Firefox browser window that showed an insecure connection, and no other tabs were functional because I didn't have internet access. I wish I'd thought to save screenshots of the addresses and windows I encountered, but I've attached the relevant portion of the browser history in case it's helpful.
