CoolhandLW
May 01, 2023Aspirant
Intermittent connectivity interruptions for both wired and wifi
Cox Cable blames the modem and says firmware is from Netgear. Netgear says Cox may need to push firmware and that it is always pushed by the provider. Netgear refuses to help more without a subscripti...
CoolhandLW
Sorry, just let me know what you need. I thought this info was in the subject line. C7000 modem-router. It cuts out every hour or so for about 5 to 15 minutes. The interruption is both wired and wifi.
May 01, 2023Guru - Experienced User
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Remove any MAC Addresses before posting.
- CoolhandLWMay 26, 2023Aspirant
Thanks for the help in advance. Sorry for the delay. I've been too busy lately to work on this. Below are the requested pastes. I replaced the valid looking MAC addresses with XXX, while I left a few that show as zeros. Looking forward to reading your responses.
Frequency start Value This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. Starting Frequency Startup Procedure
Procedure Status Comment Acquire Downstream Channel 951000000 Hz Locked Connectivity State OK Operational Boot State OK Operational Security Enabled BPI+ IP Provisioning Mode Honor MDD honorMdd(4) Downstream Bonded Channels
Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables 1 Locked QAM256 29 951000000 Hz -3.1 dBmV 38.8 dB 0 0 2 Locked QAM256 1 783000000 Hz -2.7 dBmV 40.2 dB 0 0 3 Locked QAM256 2 789000000 Hz -2.8 dBmV 40.1 dB 0 0 4 Locked QAM256 3 795000000 Hz -2.8 dBmV 40.1 dB 0 0 5 Locked QAM256 4 801000000 Hz -2.7 dBmV 40.2 dB 0 0 6 Locked QAM256 5 807000000 Hz -2.8 dBmV 40.1 dB 0 0 7 Locked QAM256 6 813000000 Hz -3 dBmV 40 dB 0 0 8 Locked QAM256 7 819000000 Hz -3 dBmV 40 dB 0 0 9 Locked QAM256 8 825000000 Hz -2.8 dBmV 40 dB 0 0 10 Locked QAM256 33 357000000 Hz -2.5 dBmV 40.2 dB 0 0 11 Locked QAM256 34 363000000 Hz -2.8 dBmV 40.1 dB 0 0 12 Locked QAM256 35 369000000 Hz -3.2 dBmV 40 dB 0 0 13 Locked QAM256 36 375000000 Hz -3.5 dBmV 39.9 dB 0 0 14 Locked QAM256 37 381000000 Hz -3.7 dBmV 39.8 dB 0 0 15 Locked QAM256 38 387000000 Hz -4 dBmV 39.7 dB 0 0 16 Locked QAM256 39 393000000 Hz -4.2 dBmV 39.7 dB 0 0 17 Locked QAM256 40 399000000 Hz -3.1 dBmV 40.4 dB 0 0 18 Locked QAM256 41 405000000 Hz -2.6 dBmV 40.8 dB 0 0 19 Locked QAM256 42 411000000 Hz -2.4 dBmV 41.2 dB 0 0 20 Locked QAM256 43 417000000 Hz -2.6 dBmV 40.8 dB 0 0 21 Locked QAM256 44 423000000 Hz -2.7 dBmV 40.8 dB 0 0 22 Locked QAM256 46 435000000 Hz -2.7 dBmV 40.9 dB 0 0 23 Locked QAM256 47 441000000 Hz -2.6 dBmV 41.2 dB 0 0 24 Locked QAM256 48 447000000 Hz -2.3 dBmV 41.3 dB 0 0 Upstream Bonded Channels
Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 3 5120 Ksym/sec 30300000 Hz 46.9 dBmV 2 Locked ATDMA 1 5120 Ksym/sec 17400000 Hz 46.9 dBmV 3 Locked ATDMA 2 5120 Ksym/sec 23900000 Hz 47 dBmV 4 Locked ATDMA 4 5120 Ksym/sec 36700000 Hz 46.9 dBmV 5 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 6 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 7 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 8 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV Current System Time:Fri May 26 21:40:20 2023
Time Priority Description 2023-5-26, 21:02:12 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.0;CM-VER=3.0; 2023-5-26, 21:02:14 Critical (3) UCD invalid or channel unusable;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.0;CM-VER=3.0; 2023-5-26, 21:02:14 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.0;CM-VER=3.0; 2023-5-26, 21:02:16 Critical (3) UCD invalid or channel unusable;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.0;CM-VER=3.0; 2023-5-26, 21:02:16 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.0;CM-VER=3.0; 2023-5-26, 21:02:18 Critical (3) UCD invalid or channel unusable;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.0;CM-VER=3.0; 2023-5-26, 21:02:18 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.0;CM-VER=3.0; 2023-5-26, 21:02:20 Critical (3) UCD invalid or channel unusable;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.0;CM-VER=3.0; 2023-5-26, 21:02:51 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.0;CM-VER=3.0; 2023-5-26, 21:02:52 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=XXX;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 2023-5-26, 21:02:56 Critical (3) UCD invalid or channel unusable;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.0;CM-VER=3.0; 2023-5-26, 21:02:58 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.0;CM-VER=3.0; 2023-5-26, 21:03:00 Critical (3) UCD invalid or channel unusable;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.0;CM-VER=3.0; 2023-5-26, 21:03:00 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.0;CM-VER=3.0; 2023-5-26, 21:03:01 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.0;CM-VER=3.0; 2023-5-26, 21:03:02 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=XXX;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 2023-5-26, 21:03:04 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=XXX;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 2023-5-26, 21:03:10 Critical (3) UCD invalid or channel unusable;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.0;CM-VER=3.0; 2023-5-26, 21:03:19 Critical (3) UCD invalid or channel unusable;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.0;CM-VER=3.0; 2023-5-26, 21:03:24 Critical (3) UCD invalid or channel unusable;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.1;CM-VER=3.0; 2023-5-26, 21:03:25 Critical (3) UCD invalid or channel unusable;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.1;CM-VER=3.0; 2023-5-26, 21:03:40 Critical (3) UCD invalid or channel unusable;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.1;CM-VER=3.0; 1970-1-1, 00:00:39 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=XXX;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:00:39 Critical (3) UCD invalid or channel unusable;CM-MAC=XXX;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:00:42 Notice (6) WiFi Interface [wl0] set to Channel 6 (Side-Band Channel:N/A) - Reason:INIT 1970-1-1, 00:00:42 Notice (6) WiFi Interface [wl1] set to Channel 153 (Side-Band Channel:N/A) - Reason:INIT 1970-1-1, 00:00:42 Critical (3) UCD invalid or channel unusable;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:00:50 Notice (6) Honoring MDD; IP provisioning mode = IPv4 1970-1-1, 00:00:51 Critical (3) UCD invalid or channel unusable;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:00:53 Warning (5) DHCP WARNING - Non-critical field invalid in response ;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:00:53 Critical (3) UCD invalid or channel unusable;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.0;CM-VER=3.0; 2023-5-26, 21:06:57 Critical (3) UCD invalid or channel unusable;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.1;CM-VER=3.0; 2023-5-26, 21:06:57 Notice (6) TLV-11 - unrecognized OID;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.1;CM-VER=3.0; 2023-5-26, 21:07:01 Critical (3) UCD invalid or channel unusable;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.1;CM-VER=3.0; 2023-5-26, 21:07:13 Warning (5) Unicast DSID PSN startup error 2023-5-26, 21:07:13 Critical (3) UCD invalid or channel unusable;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.1;CM-VER=3.0; 2023-5-26, 21:07:45 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.1;CM-VER=3.0; 2023-5-26, 21:07:45 Critical (3) UCD invalid or channel unusable;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.1;CM-VER=3.0; 2023-5-26, 21:19:11 Warning (5) Unicast DSID PSN startup error 2023-5-26, 21:19:12 Critical (3) UCD invalid or channel unusable;CM-MAC=XXX;CMTS-MAC=XXX;CM-QOS=1.1;CM-VER=3.0; - CoolhandLWMay 27, 2023Aspirant
Been out of town a while but posted the logs last night. The model is c7000,and only docsys 3.0, so not sure if that is the problem.
- FURRYe38May 27, 2023Guru - Experienced User
Power levels are with in specs:
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
Though you have Criticals and Warnings in the event logs. Any criticals, errors or warnings seen in the event log needs to be reviewed by the ISP and resolved. This indicates a ISP signal issue on the line up to the modem. https://highspeed.tips/docsis-events/
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
