RouterC7000v2
Jan 25, 2021Aspirant
Intermittent internet connection, model c7000v2
Internet connection drops for 5-50 seconds every now and then, Xfinity suggested checking wifi channel and reconfiguring the modem. Even though the modern is in warranty Netgear is refusing to help a...
Jan 25, 2021Guru - Experienced User
does the issue happen with wired and wireless device?
Only wireless devices?
- RouterC7000v2Jan 26, 2021Aspirant
Both, with wired and wireless.
- plemansJan 26, 2021Guru - Experienced User
do you have a screen snip of the cable connections page and the event logs?
No, I have no idea how to generate these.
Update: I changed the channel to 10 from Auto (which was on 11) and it seems fine so far, but I need to monitor for the entire day or two to see if it really resolved the issue.
