MitchVilla
Feb 07, 2021Aspirant
Intermittent network disconnection for CM1000
Hello all, I've been having issues with my network which started 3.5 weeks ago. I'm experiencing network dropouts within a specific timeframe. I've already had my ISP tech stop by and they've exp...
MitchVilla
Here are my logs for the weekend.
| Time | Priority | Description |
| 2021-02-07, 13:17:12 | Warning (5) | Dynamic Range Window violation |
| 2021-02-07, 13:17:12 | Warning (5) | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=10:0c:6b:ca:49:98;CMTS-MAC=d4:ad:71:0c:33:22;CM-QOS=1.1;CM-VER=3.1; |
| 2021-02-07, 13:17:07 | Notice (6) | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=10:0c:6b:ca:49:98;CMTS-MAC=d4:ad:71:0c:33:22;CM-QOS=1.1;CM-VER=3.1; |
| 2021-02-07, 13:17:02 | Notice (6) | TLV-11 - unrecognized OID;CM-MAC=10:0c:6b:ca:49:98;CMTS-MAC=d4:ad:71:0c:33:22;CM-QOS=1.1;CM-VER=3.1; |
| 2021-02-07, 13:17:02 | Warning (5) | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=10:0c:6b:ca:49:98;CMTS-MAC=d4:ad:71:0c:33:22;CM-QOS=1.1;CM-VER=3.1; |
| Time Not Established | Notice (6) | Honoring MDD; IP provisioning mode = IPv4 |
| Time Not Established | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=10:0c:6b:ca:49:98;CMTS-MAC=d4:ad:71:0c:33:22;CM-QOS=1.1;CM-VER=3.1; |
| Time Not Established | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=10:0c:6b:ca:49:98;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; |
| 2021-02-07, 13:15:51 | Critical (3) | Resetting the cable modem due to docsDevResetNow |
| 2021-02-07, 00:37:47 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=10:0c:6b:ca:49:98;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; |
| 2021-02-07, 00:37:36 | Critical (3) | Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=10:0c:6b:ca:49:98;CMTS-MAC=d4:ad:71:0c:33:22;CM-QOS=1.1;CM-VER=3.1; |
| 2021-02-07, 00:37:23 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=10:0c:6b:ca:49:98;CMTS-MAC=d4:ad:71:0c:33:22;CM-QOS=1.1;CM-VER=3.1; |
| 2021-02-07, 00:37:23 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=10:0c:6b:ca:49:98;CMTS-MAC=d4:ad:71:0c:33:22;CM-QOS=1.1;CM-VER=3.1; |
| 2021-02-07, 00:37:20 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=10:0c:6b:ca:49:98;CMTS-MAC=d4:ad:71:0c:33:22;CM-QOS=1.1;CM-VER=3.1; |
| 2021-02-07, 00:37:20 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=10:0c:6b:ca:49:98;CMTS-MAC=d4:ad:71:0c:33:22;CM-QOS=1.1;CM-VER=3.1; |
| 2021-02-07, 00:37:19 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=10:0c:6b:ca:49:98;CMTS-MAC=d4:ad:71:0c:33:22;CM-QOS=1.1;CM-VER=3.1; |
| 2021-02-07, 00:37:19 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=10:0c:6b:ca:49:98;CMTS-MAC=d4:ad:71:0c:33:22;CM-QOS=1.1;CM-VER=3.1; |
| 2021-02-07, 00:35:52 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=10:0c:6b:ca:49:98;CMTS-MAC=d4:ad:71:0c:33:22;CM-QOS=1.1;CM-VER=3.1; |
| 2021-02-07, 00:35:49 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=10:0c:6b:ca:49:98;CMTS-MAC=d4:ad:71:0c:33:22;CM-QOS=1.1;CM-VER=3.1; |
| 2021-02-07, 00:24:26 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=10:0c:6b:ca:49:98;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; |
| 2021-02-07, 00:24:22 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=10:0c:6b:ca:49:98;CMTS-MAC=d4:ad:71:0c:33:22;CM-QOS=1.1;CM-VER=3.1; |
| 2021-02-07, 00:24:02 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=10:0c:6b:ca:49:98;CMTS-MAC=d4:ad:71:0c:33:22;CM-QOS=1.1;CM-VER=3.1; |
| 2021-02-07, 00:24:02 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=10:0c:6b:ca:49:98;CMTS-MAC=d4:ad:71:0c:33:22;CM-QOS=1.1;CM-VER=3.1; |
| 2021-02-07, 00:23:43 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=10:0c:6b:ca:49:98;CMTS-MAC=d4:ad:71:0c:33:22;CM-QOS=1.1;CM-VER=3.1; |
| 2021-02-07, 00:23:42 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=10:0c:6b:ca:49:98;CMTS-MAC=d4:ad:71:0c:33:22;CM-QOS=1.1;CM-VER=3.1; |
| 2021-02-07, 00:23:23 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=10:0c:6b:ca:49:98;CMTS-MAC=d4:ad:71:0c:33:22;CM-QOS=1.1;CM-VER=3.1; |
| 2021-02-07, 00:23:22 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=10:0c:6b:ca:49:98;CMTS-MAC=d4:ad:71:0c:33:22;CM-QOS=1.1;CM-VER=3.1; |
| 2021-02-07, 00:22:35 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=10:0c:6b:ca:49:98;CMTS-MAC=d4:ad:71:0c:33:22;CM-QOS=1.1;CM-VER=3.1; |
| 2021-02-07, 00:22:34 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=10:0c:6b:ca:49:98;CMTS-MAC=d4:ad:71:0c:33:22;CM-QOS=1.1;CM-VER=3.1; |
| 2021-02-06, 16:30:18 | Critical (3) | Resetting the cable modem due to docsDevResetNow |
| 2021-02-04, 14:46:16 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=10:0c:6b:ca:49:98;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; |
| 2021-02-04, 14:46:02 | Critical (3) | Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=10:0c:6b:ca:49:98;CMTS-MAC=d4:ad:71:0c:33:22;CM-QOS=1.1;CM-VER=3.1; |
| 2021-02-04, 14:46:01 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=10:0c:6b:ca:49:98;CMTS-MAC=d4:ad:71:0c:33:22;CM-QOS=1.1;CM-VER=3.1; |
| 2021-02-04, 14:46:01 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=10:0c:6b:ca:49:98;CMTS-MAC=d4:ad:71:0c:33:22;CM-QOS=1.1;CM-VER=3.1; |
