MitchVilla
Feb 07, 2021Aspirant
Intermittent network disconnection for CM1000
Hello all, I've been having issues with my network which started 3.5 weeks ago. I'm experiencing network dropouts within a specific timeframe. I've already had my ISP tech stop by and they've exp...
Feb 07, 2021Guru - Experienced User
Your power is going in and out of spec from the logs.
Do you also have your cable connections page info? (shows the signal strengths)
- MitchVillaFeb 08, 2021Aspirant
Hello Plemans,
The system keeps removing my response. Not sure why that's happening, I do not see any errors/warnings. I post it and I see it for a couple of minutes then it disappears.
Upstream Bonded Channels
Channel Lock Status Modulation Channel ID Frequency Power 1 Locked ATDMA 1 36300000 Hz 41.3 dBmV 2 Locked ATDMA 2 29900000 Hz 42.5 dBmV 3 Locked ATDMA 3 23500000 Hz 42.0 dBmV 4 Locked ATDMA 4 16900000 Hz 41.5 dBmV 5 Not Locked Unknown 0 0 Hz 0.0 dBmV 6 Not Locked Unknown 0 0 Hz 0.0 dBmV 7 Not Locked Unknown 0 0 Hz 0.0 dBmV 8 Not Locked Unknown 0 0 Hz 0.0 dBmV Downstream OFDM Channels
Channel Lock Status Modulation / Profile ID Channel ID Frequency Power SNR / MER Active Subcarrier Number Range Unerrored Codewords Correctable Codewords Uncorrectable Codewords 1 Locked 0, 1, 2, 3 159 300000000 Hz 4.5 dBmV 42.8 dB 1108 ~ 2987 56746906 3926410 0 2 Not Locked 0 0 0 Hz -39.1 dBmV 0.0 dB 0 ~ 4095 0 0 0 Upstream OFDMA Channels
Channel Lock Status Modulation / Profile ID Channel ID Frequency Power 1 Not Locked Unknown 0 0 Hz 0 dBmV 2 Not Locked Unknown 0 0 Hz 0 dBmV - MitchVillaFeb 08, 2021Aspirant
this website is broken. I cannot upload my downstream table. for some reason it disappers a few minutes after I upload it with no notification or errors. I've tried uploading it as a photo, screenshot, attached table in this response. Nothing seems to work.
- falrigJul 07, 2021Aspirant
Was there ever a fix for this issue, as I am having the same issues with the CM1000
