MitchVilla
Feb 07, 2021Aspirant
Intermittent network disconnection for CM1000
Hello all, I've been having issues with my network which started 3.5 weeks ago. I'm experiencing network dropouts within a specific timeframe. I've already had my ISP tech stop by and they've exp...
MitchVilla
Feb 08, 2021Aspirant
Hello Plemans,
The system keeps removing my response. Not sure why that's happening, I do not see any errors/warnings. I post it and I see it for a couple of minutes then it disappears.
Upstream Bonded Channels
| Channel | Lock Status | Modulation | Channel ID | Frequency | Power |
| 1 | Locked | ATDMA | 1 | 36300000 Hz | 41.3 dBmV |
| 2 | Locked | ATDMA | 2 | 29900000 Hz | 42.5 dBmV |
| 3 | Locked | ATDMA | 3 | 23500000 Hz | 42.0 dBmV |
| 4 | Locked | ATDMA | 4 | 16900000 Hz | 41.5 dBmV |
| 5 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV |
| 6 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV |
| 7 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV |
| 8 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV |
Downstream OFDM Channels
| Channel | Lock Status | Modulation / Profile ID | Channel ID | Frequency | Power | SNR / MER | Active Subcarrier Number Range | Unerrored Codewords | Correctable Codewords | Uncorrectable Codewords |
| 1 | Locked | 0, 1, 2, 3 | 159 | 300000000 Hz | 4.5 dBmV | 42.8 dB | 1108 ~ 2987 | 56746906 | 3926410 | 0 |
| 2 | Not Locked | 0 | 0 | 0 Hz | -39.1 dBmV | 0.0 dB | 0 ~ 4095 | 0 | 0 | 0 |
Upstream OFDMA Channels
| Channel | Lock Status | Modulation / Profile ID | Channel ID | Frequency | Power | |||||
| 1 | Not Locked | Unknown | 0 | 0 Hz | 0 dBmV | |||||
| 2 | Not Locked | Unknown | 0 | 0 Hz | 0 dBmV |
MitchVilla
this website is broken. I cannot upload my downstream table. for some reason it disappers a few minutes after I upload it with no notification or errors. I've tried uploading it as a photo, screenshot, attached table in this response. Nothing seems to work.
- falrigJul 07, 2021Aspirant
Was there ever a fix for this issue, as I am having the same issues with the CM1000
- FURRYe38Jul 07, 2021Guru - Experienced User
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
What MFr and model wifi router do you have connected to the CM modem?
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
falrig wrote:Was there ever a fix for this issue, as I am having the same issues with the CM1000
Basically ive never seen a resolution on any of these posts, they just seem to end because the only response you get is please upload a spec sheet and nothing ever after that......looks like it disconnected.
Has there been any resolution, seems like a lot of people report the same intermittent connection issues with the CM1000 modem.......
Im using a Netgear Nighthawk 1900 wireless router
