tb2780
Aug 17, 2021Aspirant
Intermittent Packet Loss
Hi, I've been using by CM1200 modem for ~2 years without issues until a couple weeks ago where I started seeing some really bad packet loss that will happen intermittently. Some of the side effects ...
Aug 17, 2021Guru - Experienced User
Is there a wifi router system in between the CM modem and your devcies or is this happening with a wired PC connected to the back of the CM modem? What is the brand and model of the host wifi router connected to the modem?
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
tb2780
Thanks for you response!
- Is there a wifi router system in between the CM modem and your devcies or is this happening with a wired PC connected to the back of the CM modem? What is the brand and model of the host wifi router connected to the modem?
Yes, there is a Netgear R7000 router. I see this issue on both WiFi and Ethernet connections. As alluded to earlier, the packet loss appears at the second hop outside of my LAN so I don't suspect the router. But I can potentially remove that device from the equation to run further tests. - Please post a copy and paste of the modems connection status page.
The connection is listed as "Good" and attaching the Cable Information page. Is this what you are referring to? - Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
- Be sure there are no coax cable line splitters in the between the modem and ISP service box.
- Be sure your using good quality RG6 coax cable up to the modem.
Noted on these recommendations. - Be sure to power OFF the modem for 1 minute then back ON.
I've tried this multiple times and it hasn't resolved the issue
I've reviewed most of the self-help documents and I was hoping someone can help me parse my modem power level logs to see if there's any failures that can be discerned through the modem itself.
- tb2780Aug 17, 2021Aspirant
Ahh... I just realized my image uploads might be getting swallowed up. Here's an imgur link: https://imgur.com/iTKLDGG
- FURRYe38Aug 17, 2021Guru - Experienced User
Yes, there is a Netgear R7000 router. I see this issue on both WiFi and Ethernet connections. As alluded to earlier, the packet loss appears at the second hop outside of my LAN so I don't suspect the router. But I can potentially remove that device from the equation to run further tests. Yes you would need to test with out the R7000 router online. Direct PC to modem and test.
What FW version is loaded on the CM modem?
The connection is listed as "Good" and attaching the Cable Information page. Is this what you are referring to? Seeing lots of Correctables and Un-correctables in that list. This would be a ISP signal line issue that the ISP needs to look into. Should be minimal or nothing is these sections.
- Be sure there are no coax cable line splitters or attenuators in the between the modem and ISP service box.
