tb2780
Aug 17, 2021Aspirant
Intermittent Packet Loss
Hi, I've been using by CM1200 modem for ~2 years without issues until a couple weeks ago where I started seeing some really bad packet loss that will happen intermittently. Some of the side effects ...
tb2780
Thanks for you response!
- Is there a wifi router system in between the CM modem and your devcies or is this happening with a wired PC connected to the back of the CM modem? What is the brand and model of the host wifi router connected to the modem?
Yes, there is a Netgear R7000 router. I see this issue on both WiFi and Ethernet connections. As alluded to earlier, the packet loss appears at the second hop outside of my LAN so I don't suspect the router. But I can potentially remove that device from the equation to run further tests. - Please post a copy and paste of the modems connection status page.
The connection is listed as "Good" and attaching the Cable Information page. Is this what you are referring to? - Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
- Be sure there are no coax cable line splitters in the between the modem and ISP service box.
- Be sure your using good quality RG6 coax cable up to the modem.
Noted on these recommendations. - Be sure to power OFF the modem for 1 minute then back ON.
I've tried this multiple times and it hasn't resolved the issue
I've reviewed most of the self-help documents and I was hoping someone can help me parse my modem power level logs to see if there's any failures that can be discerned through the modem itself.
tb2780
Ahh... I just realized my image uploads might be getting swallowed up. Here's an imgur link: https://imgur.com/iTKLDGG
