Slr8929
Jan 31, 2022Aspirant
Internet connection coming and going I have Xfinity internet 600Mbps
On January 26, 2022 at night I completely lost internet connection and all the lights on the cable modem right router were on and green I restarted my router and had internet connection again but I c...
Jan 31, 2022Guru - Experienced User
Also the EX3700 would not be a good match for the C7000, the EX7000 would, IF an EX is needed. For a 1300 sq ft home a EX shouldn't be needed if the modem is placed centrally in the home on the main floor.
Slr8929
Ok so I disconnected the extender and seems to be working fine im attaching upstream and downstream logs I think they are ok but I need someone to take a look at them thanks!
- FURRYe38Jan 31, 2022Guru - Experienced User
Power levels maybe a bit too high.
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
Correctables and Uncorrectables are zero which is good. Might ask the ISP to maybe turn down the power a couple of notches?
- Slr8929Feb 01, 2022AspirantThe isp (xfinity) said the power levels were within specs so I don’t know, I haven’t lost internet connection since 4:00pm Sunday January 30,2022 but now my wifi speeds are very slow they also told me my receive powers are a bit low, again I don’t know anything about that either
- FURRYe38Feb 02, 2022Guru - Experienced User
If power levels are low then they need to help with that. Ask them to send out a tech and have them check all cabling, connections and signals up to the modem to be sure.
