Parkourpotato
Jul 13, 2016Aspirant
Internet connection doesn't work for a few seconds then comes back
Hello everyone, I'm not sure if this is a problem with my internet service provider or the actual modem, but I've been having this problem ever since I switched to this new modem. I had an old one...
Parkourpotato
Jul 21, 2016Aspirant
Ok update on the issue. Now instead of it occuring every few minutes it occurs every few seconds. Here are the logs:
| Description | Count | Last Occurrence | Target | Source |
| [TCP- or UDP-based Port Scan] | 4 | Sun Jul 17 08:04:00 2016 | 68.12.174.141:56244 | 68.105.28.11:53 |
| [FAILURE: User interface login] | 1 | Sun Jul 17 08:08:00 2016 | 192.168.0.1:80 | 192.168.0.4:50462 |
| [TCP- or UDP-based Port Scan] | 3 | Sun Jul 17 10:07:41 2016 | 68.12.174.141:61892 | 68.105.28.11:53 |
| [FAILURE: User interface login] | 1 | Sun Jul 17 10:11:23 2016 | 192.168.0.1:80 | 192.168.0.4:49839 |
| [TCP- or UDP-based Port Scan] | 91 | Mon Jul 18 01:31:20 2016 | 68.12.174.141:59154 | 68.105.28.11:53 |
| [Time Of Day established] | 1 | Mon Jul 18 07:54:47 2016 | 0.0.0.0:0 | 0.0.0.0:0 |
| [Public Network Interface up] | 1 | Mon Jul 18 07:55:01 2016 | 0.0.0.0:0 | 0.0.0.0:0 |
| [Firewall Up] | 1 | Mon Jul 18 07:55:01 2016 | 0.0.0.0:0 | 0.0.0.0:0 |
| [Teardrop or derivative] | 16 | Mon Jul 18 07:55:14 2016 | 239.255.255.250:65535 | 192.168.0.10:65535 |
| [TCP- or UDP-based Port Scan] | 15 | Mon Jul 18 13:00:16 2016 | 68.12.174.141:55528 | 68.105.29.11:53 |
| [FAILURE: User interface login] | 1 | Mon Jul 18 13:02:31 2016 | 192.168.0.1:80 | 192.168.0.5:63794 |
| [SUCCESS: User interface login] | 1 | Mon Jul 18 13:02:38 2016 | 192.168.0.1:80 | 192.168.0.5:63814 |
| [TCP- or UDP-based Port Scan] | 104 | Tue Jul 19 13:58:08 2016 | 68.12.174.141:50986 | 68.105.28.11:53 |
| [FAILURE: User interface login] | 1 | Tue Jul 19 14:01:24 2016 | 192.168.0.1:80 | 192.168.0.5:53258 |
| [SUCCESS: User interface login] | 1 | Tue Jul 19 14:01:31 2016 | 192.168.0.1:80 | 192.168.0.5:53265 |
| [TCP- or UDP-based Port Scan] | 18 | Tue Jul 19 17:55:14 2016 | 68.12.174.141:43943 | 68.105.28.11:53 |
| [FAILURE: User interface login] | 1 | Tue Jul 19 17:56:46 2016 | 192.168.0.1:80 | 192.168.0.4:54581 |
| [TCP- or UDP-based Port Scan] | 68 | Wed Jul 20 15:00:21 2016 | 68.12.174.141:59628 | 68.105.28.11:53 |
| [FAILURE: User interface login] | 1 | Wed Jul 20 15:16:51 2016 | 192.168.0.1:80 | 192.168.0.4:49790 |
| [TCP- or UDP-based Port Scan] | 70 | Thu Jul 21 12:37:35 2016 | 68.12.174.141:61056 | 68.105.28.11:53 |
| [Time Of Day established] | 1 | Thu Jul 21 13:50:55 2016 | 0.0.0.0:0 | 0.0.0.0:0 |
| [Public Network Interface up] | 1 | Thu Jul 21 13:51:10 2016 | 0.0.0.0:0 | 0.0.0.0:0 |
| [Firewall Up] | 1 | Thu Jul 21 13:51:10 2016 | 0.0.0.0:0 | 0.0.0.0:0 |
| [Teardrop or derivative] | 2 | Thu Jul 21 13:51:24 2016 | 239.255.255.250:65535 | 192.168.0.10:65535 |
| [TCP- or UDP-based Port Scan] | 1 | Thu Jul 21 13:51:24 2016 | 68.12.174.141:54572 | 68.105.28.11:53 |
| [Teardrop or derivative] | 14 | Thu Jul 21 13:51:27 2016 | 239.255.255.250:65535 | 192.168.0.10:65535 |
| [FAILURE: User interface login] | 1 | Thu Jul 21 13:56:41 2016 | 192.168.0.1:80 | 192.168.0.4:49846 |
| [TCP- or UDP-based Port Scan] | 1 | Thu Jul 21 13:59:05 2016 | 68.12.174.141:62975 | 68.105.28.11:53 |
| [FAILURE: User interface login] | 2 | Thu Jul 21 14:01:23 2016 | 192.168.0.1:80 | 192.168.0.5:55224 |
| [SUCCESS: User interface login] | 1 | Thu Jul 21 14:01:29 2016 | 192.168.0.1:80 | 192.168.0.5:55226 |
DarrenM
Jul 26, 2016Sr. NETGEAR Moderator
Hello Parkourpotato
You could try to factory reset the modem but you will have to set it up again with all your settings it could be some bad setting causing the issues.
DarrenM
