gagandeep's avatar
Oct 21, 2019
Internet connection drop while going from router to access point and vice-versa
Hi. I have the following configuration at home: Internet= Spectrum - I use spectrum docsis 3.1 cable modem Router = X4S R7800 (Mu-Mimo router) - IP address 192.168.0.2 with DHCP assignment 192.168...
  • DR650SE's avatar
    DR650SE
    Nov 04, 2019
    That makes sense. As I dug a bit deeper and took a look at the logs, I noticed I was getting errors the referenced time being out of sync. Since this is being used as an access point and not hooked up to cable, there was no way to update the time. I'm assuming this error is causing the disconnects. So now I'm looking for a new router that has a proper AP mode. Once I pick on up, the C7000 will be for sale. As a modem/router, the C7000 was solid. As an AP, not so much. Thanks for the update!
