gagandeep
Oct 21, 2019Guide
Internet connection drop while going from router to access point and vice-versa
Hi. I have the following configuration at home: Internet= Spectrum - I use spectrum docsis 3.1 cable modem Router = X4S R7800 (Mu-Mimo router) - IP address 192.168.0.2 with DHCP assignment 192.168...
- Nov 04, 2019That makes sense. As I dug a bit deeper and took a look at the logs, I noticed I was getting errors the referenced time being out of sync. Since this is being used as an access point and not hooked up to cable, there was no way to update the time. I'm assuming this error is causing the disconnects. So now I'm looking for a new router that has a proper AP mode. Once I pick on up, the C7000 will be for sale. As a modem/router, the C7000 was solid. As an AP, not so much. Thanks for the update!
DR650SE
Oct 22, 2019Guide
I'm hoping to find some resolution to this as well. I too set up a C7000 as an AP two days ago and it's the same exact issue. From my Galaxy S9+ I have to turn WiFi off and back on when the internet stops working. Nothing changes, but it just stops. It can't be going to sleep or anything becuase it happens while I'm using it. Everything else works fine, but connectivity keeps dropping or hanging. I'm using the C7000 to provide signal to the front of my house and bedroom. My R7000P is my main router and it's in the basement and the back of my house so I had ro run cable (CAT6) two floors up through the wall to connect the two.
gagandeep
Nov 04, 2019Guide
Hi DR650SE - I raised Netgear ticket under R7800 as it was new and I had complementary support. I blamed R7800 for the error. However, the customer support expert told me that converting C7000 to AP (or using it without cable) was not recommended and could be cause of the error. Thereafter, I removed C7000 and instead used an old R6900P as AP; there were no issues when a client device moved from R7800 coverage area to R6900P covered area and vice versa. As of now, I have removed R6900P. I am using Asus AX88U wifi-6 router as primary with R7800 as AP. No issues again. C7000 is up for sale!
- DR650SENov 04, 2019GuideThat makes sense. As I dug a bit deeper and took a look at the logs, I noticed I was getting errors the referenced time being out of sync. Since this is being used as an access point and not hooked up to cable, there was no way to update the time. I'm assuming this error is causing the disconnects. So now I'm looking for a new router that has a proper AP mode. Once I pick on up, the C7000 will be for sale. As a modem/router, the C7000 was solid. As an AP, not so much. Thanks for the update!
- gagandeepNov 04, 2019GuideHi DR650SE. My ISP is spectrum and they provide Spectrum Hitron docsis 3.1 (possibly with puma chip) for free. The ping times were generally 6-10 ms while doing speed test and the internet throttled to top permissible speed instantaneously. I purchased my own latest and greatest Motorola MB8600 and Netgear CM1100 but I always got ping of 11-14 ms so returned those and stuck with free modem from my ISP! Also if you are looking for router, keep in mind most WiFi 6 routers do not fully support OFDMA uplink and are referred to as draft routers. I would advise you to do some research before investing in a router.
