CD2022
Jul 04, 2022Tutor
Internet disconnected when replacing w new Spectrum Modem model ET2251 to the system w Netgear C3000
My current set up is cable (white) from wall to a cable splitter: 1 cable (white) to new Modem Spectrum ET2251 and other cable (white) to Router Netgear C3000. Landline phone cable (gray) from wall c...
- Jul 07, 2022
Glad you got it working well.
You might mark it solved so others aren't trying to continue to fix it.
Hope the new router works well.
CD2022
Jul 05, 2022Tutor
Thanks for the information. I need to buy a new wi-fi router. My internet service plan with (measured) download: 300 Mbps+ and upload: 11 Mbps. Do you have any recommendation for a good, economical Netgear wi-fi router serving a 1500 s.f. single story home?
michaelkenward
Jul 06, 2022Guru - Experienced User
With so many routers available it is hard to say which is best for a particular user.
Try plugging your needs into the filters on the product pages:
Wireless Routers for Home | NETGEAR
and
Orbi: Whole Home WiFi System for Better WiFi Everywhere | NETGEAR
Then check back here for reports on the things you are considering, but remember that people turn up in this community with problems, not compliments. So look at reviews on Amazon, for example.
