CD2022
Jul 04, 2022Tutor
Internet disconnected when replacing w new Spectrum Modem model ET2251 to the system w Netgear C3000
My current set up is cable (white) from wall to a cable splitter: 1 cable (white) to new Modem Spectrum ET2251 and other cable (white) to Router Netgear C3000. Landline phone cable (gray) from wall c...
- Jul 07, 2022
Glad you got it working well.
You might mark it solved so others aren't trying to continue to fix it.
Hope the new router works well.
CD2022
Jul 05, 2022Tutor
Thanks for the information. I need to buy a new wi-fi router. My internet service plan with (measured) download: 300 Mbps+ and upload: 11 Mbps. Do you have any recommendation for a good, economical Netgear wi-fi router serving a 1500 s.f. single story home?
Jul 06, 2022Guru - Experienced User
while I'm a fan of using michaelkenward suggestion for filter by your needs, I'd also check amazon. There's been a bunch of "renewed" routers on there for much cheaper. so you can get better performance/specs for a lower price. Even adding in an aftermarket warranty and you come up quite a bit cheaper. I've had friends/family take that route.
- CD2022Jul 07, 2022Tutor
Thanks for the info. I bought a Netgear AX1800 router for this. It works well so far. Thanks for everyone's help.
