CD2022
Jul 04, 2022Tutor
Internet disconnected when replacing w new Spectrum Modem model ET2251 to the system w Netgear C3000
My current set up is cable (white) from wall to a cable splitter: 1 cable (white) to new Modem Spectrum ET2251 and other cable (white) to Router Netgear C3000. Landline phone cable (gray) from wall c...
- Jul 07, 2022
Glad you got it working well.
You might mark it solved so others aren't trying to continue to fix it.
Hope the new router works well.
CD2022
Jul 07, 2022Tutor
Thanks for the info. I checked with Best Buy tech and Spectrum and bought a Netgear AX1800 router. It works well. My old modem/router do not work with the new internet service plan. Thanks for everyone's help.
michaelkenward
Jul 08, 2022Guru - Experienced User
That's good.
If you need to come back for more help, note that AX1800 isn't a Netgear model number. AX1800 is not a reliable guide to model number. Many devices come with an AX tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
Look at the label on the device for the model number.
In this case, it is probably one of Netgear's WiFi 6 devices.Depending in which one you bought, user to user self support probably happens in one of these places:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
Orbi WiFi 6 (AX) and WiFi 6E (AXE) - NETGEAR Communities
With luck, though, you won't need help.
