sunday256
Jul 08, 2020Aspirant
Internet disconnects every 12 hours at approximately same time each occurrence
Good morning, I have a Netgear Gateway C6300V2 that has been disconnecting from the internet approximately every 12 hours. The lights on the device look normal like my connectivity is good/on, but th...
sunday256
The line was checked approximately 1 to 1.5 years ago and everything was great when he replaced one of the coax cables. He checked the signal from the box to the modem and it was pretty good so I doubt anything has changed there since. I could call someone out but likely will be charged a service fee to do so. If this wasn't every 12 hours or so I would think it might be something cable wise, but this is pretty much every 12.2 hours or so. So it's very specific. It doesn't happen randomly. As for neighbors on wifi, yes there are a bunch but the disconnects happen even at 4am, so I don't think it's a usage thing. It started at 4pm/4am and gradually moved to 6pm/6am over a few weeks.
Jul 08, 2020Guru - Experienced User
What WiFi channels are the neighbors using?
Yes seems to be a specific kind of even happening.
I would have the ISP check there signals up to the modem and also check there logs to see if they notice this same thing happening as well.
You may want to try a different modem, even rent a ISP one short term to see if same thing happens or not.
