MasterIBIS
Jul 21, 2022Aspirant
Internet dropping intermittently
I have been having a lot of issues with my internet dropping randomly for 5secs to 15 minutes. This affects both wifi and wired and nothing reboots. -Xfinity is my ISP and have replaced the wir...
Jul 21, 2022Guru - Experienced User
Any chance you can put that in a PDF or take a screen capture of the cable connections page?
MasterIBIS
- FURRYe38Jul 21, 2022Guru - Experienced User
Power levels are a bit high but with in specs. Might check into a attenuator maybe.
However you have a ton of correct and un-correctables that should be zero's.
Need to check coax cabling and fittings. Remove any splitters and ensure fittings are snug and fit. No kinks and such in the cabling line.
B sure coax cable is of good quality RG6.
- MasterIBISJul 21, 2022AspirantOkay, I will and will report back. Thanks
- MasterIBISJul 23, 2022Aspirant
New wire, same thing. Saw this though from the router
[admin login] from source 192.168.1.44, Sunday, July 24, 2022 00:50:56
[DHCP IP: 192.168.1.35][Device Name: ] to MAC address 8a:a5:71:64:a7:f0, Sunday, July 24, 2022 00:42:49
[DHCP IP: 192.168.1.6][Device Name: ] to MAC address e4:a8:df:48:5a:a9, Sunday, July 24, 2022 00:41:54
[DoS Attack: ACK Scan] from source: 8.251.221.124, port 443, Sunday, July 24, 2022 00:41:50
[DoS Attack: ACK Scan] from source: 8.252.167.252, port 443, Sunday, July 24, 2022 00:41:20
[DHCP IP: 192.168.1.14][Device Name: ] to MAC address 00:04:4b:b6:35:22, Sunday, July 24, 2022 00:40:17
[DHCP IP: 192.168.1.44][Device Name: SEBASTIAN] to MAC address 50:eb:71:0f:ee:9d, Sunday, July 24, 2022 00:40:16
[DHCP IP: 192.168.1.5][Device Name: AMAZON-03C781ED0] to MAC address e4:a8:df:1e:7a:60, Sunday, July 24, 2022 00:39:54
[DoS Attack: ACK Scan] from source: 8.251.221.124, port 443, Sunday, July 24, 2022 00:39:48
[DoS Attack: ACK Scan] from source: 8.252.167.252, port 443, Sunday, July 24, 2022 00:39:21
[DoS Attack: ACK Scan] from source: 162.247.241.4, port 443, Sunday, July 24, 2022 00:38:59
[DoS Attack: ACK Scan] from source: 162.247.241.4, port 443, Sunday, July 24, 2022 00:38:55
[Time synchronized with NTP server]
[DoS Attack: ACK Scan] from source: 162.247.241.14, port 443, Sunday, July 24, 2022 00:38:53
[Time synchronized with NTP server] Sunday, July 24, 2022 00:38:49
[Internet connected] IP address: 73.46.242.168, Sunday, July 24, 2022 00:38:47
[Initialized, firmware version: V1.2.3.28] Sunday, July 24, 2022 00:38:47
