OppaStoppa
Feb 03, 2021Tutor
Internet dropping
I recently moved into my gf house and the only internet service they have in the area is spectrum. The internet always drops throughtout the day. I bought a CM1200 thinking it will fix the problem. I...
OppaStoppa
Feb 03, 2021Tutor
The tech guy came last week and it was solid for 2 days and continue to happen. i will take a picture of his work outside.
Feb 03, 2021Guru - Experienced User
Use the Choose File button at the bottom of the text edit window when you relay to a post, and or include any links to pictures posted on picture hosting sites in your post.
- OppaStoppaFeb 03, 2021Tutor
https://i.ibb.co/QDSX830/Screen-Shot-2021-02-03-at-8-02-33-PM.png
https://i.ibb.co/5kyVz1n/Screen-Shot-2021-02-03-at-8-02-59-PM.png
https://i.ibb.co/bJphb8z/Screen-Shot-2021-02-03-at-8-03-09-PM.png- FURRYe38Feb 03, 2021Guru - Experienced User
Possible your Power Level are a bit to high?
Here is mine:
Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables 1 Locked QAM256 31 837000000 Hz -2.4 dBmV 37 dB 0 0 2 Locked QAM256 2 657000000 Hz -2.4 dBmV 36.5 dB 0 0 3 Locked QAM256 3 663000000 Hz -2.2 dBmV 36.7 dB 0 0 4 Locked QAM256 4 669000000 Hz -2.1 dBmV 36.6 dB 0 0 5 Locked QAM256 5 675000000 Hz -2 dBmV 36.7 dB 0 0 6 Locked QAM256 6 681000000 Hz -1.8 dBmV 36.9 dB 0 0 7 Locked QAM256 7 687000000 Hz -1.7 dBmV 36.8 dB 0 0 8 Locked QAM256 8 693000000 Hz -1.6 dBmV 36.9 dB 0 0 9 Locked QAM256 9 699000000 Hz -1.3 dBmV 37 dB 0 0 10 Locked QAM256 10 705000000 Hz -1.4 dBmV 36.9 dB 0 0 11 Locked QAM256 11 711000000 Hz -1.1 dBmV 36.9 dB 0 0 12 Locked QAM256 12 717000000 Hz -0.7 dBmV 37.1 dB 0 0 13 Locked QAM256 13 723000000 Hz -0.9 dBmV 36.9 dB 0 0 14 Locked QAM256 14 729000000 Hz -0.7 dBmV 36.8 dB 0 0 15 Locked QAM256 15 735000000 Hz -0.5 dBmV 37 dB 0 0 16 Locked QAM256 16 741000000 Hz -0.5 dBmV 37 dB 0 0 17 Locked QAM256 17 753000000 Hz -0.6 dBmV 37.1 dB 0 0 18 Locked QAM256 18 759000000 Hz -0.8 dBmV 37.1 dB 0 0 19 Locked QAM256 19 765000000 Hz -1.2 dBmV 37.1 dB 0 0 20 Locked QAM256 20 771000000 Hz -1.3 dBmV 37.2 dB 0 0 21 Locked QAM256 21 777000000 Hz -1.4 dBmV 37.3 dB 0 0 22 Locked QAM256 22 783000000 Hz -1.6 dBmV 37.3 dB 0 0 23 Locked QAM256 23 789000000 Hz -1.6 dBmV 37.3 dB 0 0 24 Locked QAM256 24 795000000 Hz -1.8 dBmV 37.3 dB 0 0 25 Locked QAM256 25 801000000 Hz -2 dBmV 37.1 dB 0 0 26 Locked QAM256 26 807000000 Hz -2 dBmV 37.2 dB 0 0 27 Locked QAM256 27 813000000 Hz -2 dBmV 37.2 dB 0 0 28 Locked QAM256 28 819000000 Hz -2.5 dBmV 36.9 dB 0 0 29 Locked QAM256 29 825000000 Hz -2.3 dBmV 37.2 dB 0 0 30 Locked QAM256 30 831000000 Hz -2.4 dBmV 37.1 dB 0 0 31 Locked QAM256 32 843000000 Hz -2.5 dBmV 37 dB 0 0 32 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 Upstream Bonded Channels Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 1 5120 Ksym/sec 36000000 Hz 39 dBmV 2 Locked ATDMA 2 5120 Ksym/sec 29000000 Hz 37.8 dBmV 3 Locked ATDMA 5 5120 Ksym/sec 22000000 Hz 38.3 dBmV 4 Locked ATDMA 6 2560 Ksym/sec 16000000 Hz 37.3 dBmV 5 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 6 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 7 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 8 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV Downstream OFDM Channels Channel Lock
StatusModulation /
Profile IDChannel
IDFrequency Power SNR /
MERActive Subcarrier
Number RangeUnerrored
CodewordsCorrectable
CodewordsUncorrectable
Codewords1 Locked 0 ,1 ,2 33 547000000 Hz -4.1 dBmV 36.5 dB 1108 ~ 2987 7102873230 5418783979 12 2 Not Locked 0 0 0 Hz 0 dBmV 0.0 dB 0 ~ 4095 0 0 0 Upstream OFDMA Channels Channel Lock Status Modulation / Profile ID Channel ID Frequency Power 1 Not Locked 0 0 0 Hz 0 dBmV 2 Not Locked 0 0 0 Hz 0 dBmV - OppaStoppaFeb 03, 2021Tutor
is there a way to lower it? I been having this problem with spectrum modem and a arris modem i bought. i dont think the modem is the problem.
