OppaStoppa
Feb 03, 2021Tutor
Internet dropping
I recently moved into my gf house and the only internet service they have in the area is spectrum. The internet always drops throughtout the day. I bought a CM1200 thinking it will fix the problem. I...
Feb 05, 2021Guru - Experienced User
remove any extra connections.
Can you swap the crawlspace cable for a different connection to see if the crawlspace cable is the issue?
OppaStoppa
Feb 05, 2021Tutor
I was thinking replacing the crawl space cable. Spectrum coming today. I’m going to ask him to run a new line. If , nothing is solved. My next step will be to replace the underground line running to the pole. Will be hard tho, having a horse.
