mattbyar01's avatar
mattbyar01
internet drops with C7000v2 router
I recently purchased the C7000v2 modem/router and have experienced my internet connection dropping intermittenly for 45 seconds to 1 minute.  I have verified that my router has the latest release of firmware, V1.02.12.  I never had this issue with my previous C7000 modem/router.  Does anyone have any suggestions to correct the issue?
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Are you able to check the modem logs and check if you have any T3 or T4 timeouts?
    DarrenM
      • DarrenM's avatar
        DarrenM
        That typically indicates a signal issue with the ISP you may need to have them come check out your lines.
        DarrenM
