MattWiddicombe
Aug 06, 2019Follower
Internet keeps flashing in and out
So we've had this Netgear router for a couple years now and we haven't had any problems with it until now. It seems that every 1-5 minutes every device connected to the wifi (including phones, laptops...
Aug 07, 2019Guru - Experienced User
Please post about this here for your model router:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
Good Luck.
MattWiddicombe wrote:
So we've had this Netgear router for a couple years now and we haven't had any problems with it until now. It seems that every 1-5 minutes every device connected to the wifi (including phones, laptops, and an Xbox) will disconnect for about a second or two and then reconnect. This causes many problems especially with the Xbox and makes it hard to use the wifi for long periods of time.
Here's a list on everything we have tried so far:
* Turning off the router and waiting 30 seconds before turning it back on.
* Doing the same thing as above but with the modem as well.
* Doing a complete factory reset by holding the factory reset button down for 7 seconds and then rebooting the router as done above.
* Updating the firmware online to the latest version and rebooting again.
* And finally after calling support they told us to hold the factory reset button for a whole minute this time and then reboot and update the firmware, but it told me that there were no new versions to update to.
After trying all of these nothing has fixed it and the problem still occurs. If anyone has had this problem before or know of a solution to this let me know please I would greatly appreciate it.
