gideon1234
Aug 03, 2020Initiate
Internet light on, but modem still not working? CM 400
Hi all, Having an issue with my modem where all the lights are on, yet I'm still not able to connect to the internet. I know that it's the modem, and not the router, because even with an ethernet c...
- Aug 03, 2020
Have the ISP check the signal and line quality UP to the modem. Have them re-send there configuration file to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
Aug 03, 2020Guru - Experienced User
gideon1234
Aug 05, 2020Initiate
This worked! I called my ISP and asked them to re-send configuration file and that fixed the problem- Thank you!!!
- FURRYe38Aug 05, 2020Guru - Experienced User
Glad it's working now. Enjoy. :smileywink:
