xcentrik05
Sep 24, 2015Aspirant
Internet lights out, no US, slow DS
I have a CM3700. Everything was working fine for a few months. Yesterday I lost internet access. I checked my router and the internet light is out and the DS light is slow flashing, no US. The ISP ins...
Babylon5
Sep 25, 2015NETGEAR Employee Retired
Have you checked the coax cable, these can be easily damaged?
- xcentrik05Sep 25, 2015Aspirant
The coax cable appears to be fine to me. I traced it from the house to the box and don't see any damage.
- Babylon5Sep 26, 2015NETGEAR Employee Retired
I was thinking more of the connector ends, typically a bent centre pin or the connector itself simply loose, it is also possible for the centre core of the coax to break if the cable is bent too much. This is perhaps less likely if the router suddenly stopped communicating with the ISP without it being moved.
Do you have any friends or good neighbours using a cable ISP where you could connect your router just to see if it detects a signal from the ISP equipment?
Is you router still within the hardware warranty period? Is so you could contact Technical Support who may offer you an RMA if they agree it’s a hardware failure.
- xcentrik05Sep 26, 2015Aspirant
Unfortunately I don't have any friends using cable internet. I just went out and bought another C3700. I plugged it in and got the exact same issue. internet light is black, DS light is slow blinking. My router is still under warranty, only 4months old but I don't have a receipt or anything like that for it. Forgot to register it as well. But it appears the issue isn't with the router.
