meliodas
Jul 10, 2016Aspirant
internet not working
I was fiddling with settings on my router a cg3000-2spawn and turned bridge mode on out of curiosity and now I cannot connect to my router at all even with a cake,I have tried a factory reset and still nothing is working.
- meliodasAspirantWith a cable *
- DarrenMSr. NETGEAR Moderator
Hello meliodas
go to google and type in my ip then copy that ip address and then put that into your url bar see if it lets you connect to the modem. If that does not work you may need to do a ipconfig to find the default gateway address of the modem.
https://oit.ncsu.edu/computer-setup-for-resnet/ipconfig-in-windows/
DarrenM
