-Enrique-
Feb 12, 2021Aspirant
Internet problem AC1200 C6220 after idle for few hours
Hello, on Lan network but differ from Com, Infin and others titled. After a few hours, the internet stags and the internet button does this static blinking and I have no internet access until i turn ...
Feb 12, 2021Guru - Experienced User
do you have a screen snip of the cable connections page and the event logs?
that helps us check the connect back to the isp.
- -Enrique-Feb 12, 2021Aspirant
Time Priority Description 2021-02-12, 10:29:33.0 Warning (5) MDD message timeout;CM-MAC=bc:a5:11:d2:8f:fc;CMTS-MAC=00:90:f0:0b:02:10;CM-QOS=1.1;CM-VER=3.0; 2021-02-12, 10:29:03.0 Error (4) Missing BP Configuration Setting TLV Type: 17.1;CM-MAC=bc:a5:11:d2:8f:fc;CMTS-MAC=00:90:f0:0b:02:10;CM-QOS=1.1;CM-VER=3.0; 2021-02-12, 10:29:03.0 Error (4) Missing BP Configuration Setting TLV Type: 17.2;CM-MAC=bc:a5:11:d2:8f:fc;CMTS-MAC=00:90:f0:0b:02:10;CM-QOS=1.1;CM-VER=3.0; 2021-02-12, 10:29:03.0 Error (4) Missing BP Configuration Setting TLV Type: 17.3;CM-MAC=bc:a5:11:d2:8f:fc;CMTS-MAC=00:90:f0:0b:02:10;CM-QOS=1.1;CM-VER=3.0; 2021-02-12, 10:29:03.0 Error (4) Missing BP Configuration Setting TLV Type: 17.4;CM-MAC=bc:a5:11:d2:8f:fc;CMTS-MAC=00:90:f0:0b:02:10;CM-QOS=1.1;CM-VER=3.0; 2021-02-12, 10:29:03.0 Error (4) Missing BP Configuration Setting TLV Type: 17.5;CM-MAC=bc:a5:11:d2:8f:fc;CMTS-MAC=00:90:f0:0b:02:10;CM-QOS=1.1;CM-VER=3.0; 2021-02-12, 10:29:03.0 Error (4) Missing BP Configuration Setting TLV Type: 17.6;CM-MAC=bc:a5:11:d2:8f:fc;CMTS-MAC=00:90:f0:0b:02:10;CM-QOS=1.1;CM-VER=3.0; 2021-02-12, 10:29:03.0 Error (4) Missing BP Configuration Setting TLV Type: 17.7;CM-MAC=bc:a5:11:d2:8f:fc;CMTS-MAC=00:90:f0:0b:02:10;CM-QOS=1.1;CM-VER=3.0; 2021-02-12, 10:29:03.0 Error (4) Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=bc:a5:11:d2:8f:fc;CMTS-MAC=00:90:f0:0b:02:10;CM-QOS=1.1;CM-VER=3.0; 2021-02-12, 10:29:03.0 Error (4) Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=bc:a5:11:d2:8f:fc;CMTS-MAC=00:90:f0:0b:02:10;CM-QOS=1.1;CM-VER=3.0; 2021-02-12, 10:29:02.0 Warning (5) DHCP WARNING - Non-critical field invalid in response ;CM-MAC=bc:a5:11:d2:8f:fc;CMTS-MAC=00:90:f0:0b:02:10;CM-QOS=1.0;CM-VER=3.0; 2021-02-11, 23:48:42.0 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=bc:a5:11:d2:8f:fc;CMTS-MAC=00:90:f0:0b:02:10;CM-QOS=1.1;CM-VER=3.0; 2021-02-11, 23:48:42.0 Critical (3) Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=bc:a5:11:d2:8f:fc;CMTS-MAC=00:90:f0:0b:02:10;CM-QOS=1.1;CM-VER=3.0; 2021-02-11, 23:48:42.0 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream channel 0;CM-MAC=bc:a5:11:d2:8f:fc;CMTS-MAC=00:90:f0:0b:02:10;CM-QOS=1.1;CM-VER=3.0; 2021-02-11, 23:48:36.0 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=bc:a5:11:d2:8f:fc;CMTS-MAC=00:90:f0:0b:02:10;CM-QOS=1.1;CM-VER=3.0; 2021-02-11, 23:48:36.0 Critical (3) Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=bc:a5:11:d2:8f:fc;CMTS-MAC=00:90:f0:0b:02:10;CM-QOS=1.1;CM-VER=3.0; 2021-02-11, 23:48:36.0 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream channel 2;CM-MAC=bc:a5:11:d2:8f:fc;CMTS-MAC=00:90:f0:0b:02:10;CM-QOS=1.1;CM-VER=3.0; 2021-02-11, 23:48:34.0 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=bc:a5:11:d2:8f:fc;CMTS-MAC=00:90:f0:0b:02:10;CM-QOS=1.1;CM-VER=3.0;
