acfayman
Jul 26, 2022Aspirant
Internet speed discrepancy
Hi everyone, Xfinity tells me that I'm paying for 800 Mbps download speed, but their speed test result was only 53.5. down, 17.5 up. NETGEAR speed test results: 467.98 down, 17.95 up. NETGEAR tells ...
- Jul 26, 2022
Check the Link Speed seen on this picture. You'll not see anything over that rate.
Jul 26, 2022Guru - Experienced User
Not much to go on.
What NG product are you referring too?
How are you speed testing? Wired ethernet is preferred with a PC and Ooklas installable speed test app.
Also be sure your Ethernet adapter supports 1000Mpbs and Lan cable is CAT6 is recommended.
- acfaymanJul 26, 2022Aspirant
I have Nighthawk model CAX80 purchased Feb. 2021; no provider equipment. Not sure what firmware is running, no updates available. I'm running Windows 10 and don't really have speed issues, just trying to understand the differences reported. I do experience periodic Internet outage, and Xfinity says they've boosted my signal, but it doesn't always help.
- FURRYe38Jul 26, 2022Guru - Experienced User
So where are you seeing these differences. Web site? Modems speed test web page?
FW is on the modems web page.
Please post a copy and paste of the modems connection status page.
Be sure your using a good quality LAN cable between the modem and PC. CAT6 is recommended.- acfaymanJul 26, 2022Aspirant
Differences are on the modem speed test pages.
Here is the connection status:
