Lmackedanz
Mar 23, 2018Aspirant
Internet Speed Dropping on AC1900
I currently have Cable Internet with over 100Mbs download speeds. During the day I am often getting download speeds of 28-42Mbs, however in the evening (when I will be the only one using the interne...
Mar 23, 2018Guru - Experienced User
Whats the Mfr and model# of the ISP modem? IF this modem has a built in router, it needs to be put into transparent bridge mode. If it can't be, then use the modems DMZ for the IP address the NG router gets from the modem.
Disable any wifi radios and uPnP on the modem.
- LmackedanzMar 23, 2018Aspirant
Thanks for the reply. You are going to have to bear with me as this not my area of expertise (and clearly it is yours). I have the Netgear AC1900 that I am using as my modem and router so I do not have any equipment from the ISP. I hope that answers your question....
- FURRYe38Mar 23, 2018Guru - Experienced User
Well there is a modem or ONT some place since the router doesn't actually do any kind of modem work or ONT work.
What is your ISP service? Cable or Fiber?
Where does the Yellow internet port connect too on the router? Wall outlet?
Is the NG router getting a public IP address ##.##.###.### or a private IP address, 192 or 172 or 10 something on it's internet port?
Do you have any QOS enabled?
Speed testing on ethernet connections to check speeds when this happens?
- LmackedanzApr 12, 2018Aspirant
I just realized that when I replied to another user who had questions for me I did not reply to you as well.
Here is the modem/router combo that I have :
NETGEAR - Nighthawk Dual-Band AC1900 Router with DOCSIS 3.0 Cable Modem - Black
My provider is Time Warner Cable (I guess now Spectrum)
I am not sure how to get to my IP address. I am not sure why I am experiencing such drops in my Wifi Speed when I am the only one on the network.
Thank you,
- michaelkenwardMar 24, 2018Guru - Experienced User
AC1900 is not a Netgear model number, more a wifi speed indicator.
Is this a D7000 of some sort? That's the DSL modem/routers.
For cable it could be C6300, C6900, C7000, C7100, or something else.
The model number is on the device somewhere.
- LmackedanzMar 24, 2018AspirantThank you for your clarification. I have the C7000
https://www.netgear.com/home/products/networking/cable-modems-routers/C7000.aspx
It is a modem and router combo. I am not sure how to find my IP address using my iPad (the genie app had not been helpful to me).
