Lmackedanz
Mar 23, 2018Aspirant
Internet Speed Dropping on AC1900
I currently have Cable Internet with over 100Mbs download speeds. During the day I am often getting download speeds of 28-42Mbs, however in the evening (when I will be the only one using the interne...
Lmackedanz
Thanks for the reply. You are going to have to bear with me as this not my area of expertise (and clearly it is yours). I have the Netgear AC1900 that I am using as my modem and router so I do not have any equipment from the ISP. I hope that answers your question....
michaelkenward
Mar 24, 2018Guru - Experienced User
AC1900 is not a Netgear model number, more a wifi speed indicator.
Is this a D7000 of some sort? That's the DSL modem/routers.
For cable it could be C6300, C6900, C7000, C7100, or something else.
The model number is on the device somewhere.
- LmackedanzMar 24, 2018AspirantThank you for your clarification. I have the C7000
https://www.netgear.com/home/products/networking/cable-modems-routers/C7000.aspx
It is a modem and router combo. I am not sure how to find my IP address using my iPad (the genie app had not been helpful to me).
