Tyrrox
Oct 30, 2022Aspirant
Internet Speed is Lower Than it Should be
Hey all I have tried various searches to find an answer for this, called Comcast, Asus, Netgear, had techs out and so far, nothing, but let me tell you what is going on. Last week I had 900mbps d...
Tyrrox
Oct 31, 2022Aspirant
Thanks, I am currently using it as WAN, where the modem is connecting to the router's 2.5 gbps port and the desktop and NAS are using 2 of the 1 gbps ports.
If I wanted to go the switch route like you are using which switch, would you recommend? I only really need a few ports. Also, how would the setup look? Would I go from the modem to the Switch and then from the switch to the router?
Oct 31, 2022Guru - Experienced User
The only router I know of that has a Multi gig WAN port and 1 Multi gig LAN port is the Orbi 9 series RBRE960. I has 1x 10Gb WAN port and 1x 2.5Gb LAN port along with 3x 1Gb LAN ports.
