idiaz9's avatar
idiaz9
Internet Speed Issues: R7000P and C7000v2 combo
I’m currently running Spectrum’s 1Gbps plan through a C7000v2 router/modem combo and a R7000p router (current firmware V1.3.3.154_10.1.86). My speed tests however are showing I’m only getting 100-150m...
  • idiaz9's avatar
    idiaz9
    Mar 09, 2024
    I ended up factory resetting both which seem to clear the problem. I tested the 5G connection on my phone and laptop while connected wirelessly to the R7000p router. The speed test show Wi-Fi is maxing out at 500mpbs as you said. Im now considering upgrading the modem from the C7000v2 to the CM2000 (approved for spectrum 1g) while still using the R7000p as the router.
