Jie552
Jul 17, 2023Follower
Internet speeds drops every few minutes to ~1Mbs download /.08 Mbs upload using the (C7000v2)
Repost to the relevant forum. Heyo, I am using the C7000v2 router and for the past month the download/upload speeds has been very slow and inconsistent compared to before and would drop to near 0m...
Jul 17, 2023Guru - Experienced User
You have some channels that are not getting any signal and they should be.
The channels that are getting signal, the power is TOO LOW:
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
Also see a ton of correctables and un-correctables that should be zeros.
Any Criticals, Errors or Warnings seen in the event logs page needs to be reviewed by the ISP and resolved by the ISP.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
https://highspeed.tips/docsis-events/
