Candlefire
Mar 29, 2020Aspirant
iOS Device connected to wifi, but not data
I have mostly apple products in our home. My MBP is connected fine as well as the rest of my families'. My phone and others are connected, but my wife's phone won't connect. I have reset all network ...
Mar 29, 2020Guru - Experienced User
I would have the phone looked at. IF this is the only phone thats having problems and other phones are working with the C7800, this phone needs to be looked at.
Try this, disable secuity temporarily on the C7800. Connect the phone to the modem. Does it work any? Re-enable WPA2 and AES on the C7800.
- CandlefireMar 30, 2020Aspirant
That was a good suggestion, but it did not work. Her phone still won't connect to either the 2.4 ghz or the 5 ghz networks. It will connect to the 2.4 ghz guest network, however. I just don't understand what the difference is between those networks that is causing the problem.
- FURRYe38Mar 30, 2020Guru - Experienced User
Even if that is failing, something with her phone isn't right. If it was the modem, then some if not all of your other devices would be having a problem as well.
