jacquielacoste
Sep 08, 2017Aspirant
ip cameras
how to connet ip cameras to netgear router c7000 how to get router to accept ip camera
Which "ip cameras"? Wired or wireless connection?
I don't know what that means. For a wired connection, connect the
wire. For a wireless connection, follow the instructions which come
with your (unspecified) "ip cameras".- jacquielacosteAspirantFREDI Security Camera System 8-Channel HD-TVI 1080P Lite Video Security System DVR. I don't know if I need to forward port the up address to make cameras go online wireless to watch through app. The dvr is connected directly to router
> [...] DVR.
Ok. As I read that, the DVR talks to the cameras, and you talk to
the DVR.
If you're running "app" on a device which is connected to your LAN,
then you should not need to do any port forwarding. If you want to talk
to the DVR from the outside world, then you may need to configure
port forwarding to the DVR. The DVR instructions should say whether
this is needed.
To do that, you need to ensure that the DVR always has the same IP
address. You probably should reserve an address for it somewhere like
ADVANCED > Setup > LAN Setup : Address Reservation. Then you can use
that address in ADVANCED > Advanced Setup > Port Forwarding / Port
Triggering. I assume that the DVR instructions tell you which port it
uses.
