brownbreadfox's avatar
Jul 12, 2021
IPv6 and IPv4 intermittently not supported
I have 2 laptops and 2 iphones connected to the network. IPv6 and IPv4 addresses aren't supported nondeterministicly. For example, sometimes the iphones will have IPv4 supported but not IPv6 and visa versa.
 I'm using https://ipv6-test.com/ to determine which protocols are supported.
The behavior that's annoying is that certain websites & apps won't work.
  • FURRYe38's avatar
    Do you have IPv6 enabled and configured on the modem?
    What FW is loaded on the modem?
    Whos your ISP?
    • brownbreadfox's avatar
      brownbreadfox
      Yes, IPv6 is enabled on the router.
      Xfinity is my ISP and they control the firmware upgrades.
