bbqfrito
Sep 07, 2019Follower
IPv6 DHCP Nighthawk Router C7000 Series
Is there any way to set up the DNS servers for DHCP for IPv6 so I can use my local DNS server?
The above post asked this question and it was never truly "solved".
1 Reply
Something you should contact NG support about. Maybe something thats not supported on C series modems. Loopback maybe needed which may not be supported on modems.
