sgage
Apr 28, 2017Tutor
IPV6 disable is same as IPV6 firewall?
A third party dns supplier says I need to disable my ipv6 in order to get a game console app to work properly. I disabled the firewall protection but they said that is not actually disabling it. Is there something beyond firewall protection and how do I disable?
Firmware V2.02.08
- DarrenMSr. NETGEAR Moderator
Hello sgage
Did you ever find a solution to this?
DarrenM
No. So the only IPV6 disable is the firewall disable? And if I disable that firewall, it should be reflected in the settings on my xbox one? After putting in the google dns settings in my xbox, which allowed me to see games other than live in-market, I deleted the dns settings, thinking that it would revert back to my Overplay dns settings in my modem/router. Apparently not since I get another mlb message that I am not connected to network.
Note that this same discussion is here:
I didn't think my first start of the discussion was successful. Is there a way to merge the discussions?
